BadBoy outlaw modification
lightning12
I want to speed up my outlaw. It does 12 mph but with the 36 hp Briggs I believe it could go faster? Does anyone know how to do this or if it can be done?
txzrider
larger diameter tires.
lightning12
It has 24x12x10 on it now do they make anything bigger? Not sure i have clearance for much larger.
txzrider
no idea, however w/o knowing the limitations of how many rpm's you can spin the hydros to... you cant be sure it is safe to change pulley size to get them to turn faster thereby giving you a higher top speed. Only other method I could think of besides tire diameter and/or pulley diameter would be engine speed.
Ric
Why do you want to speed it up, you can't mow at the speed you have now and get a decent cut.
scott47429
well i can mow with my Exmark at full speed and thats 11 mph and get a great cut
txzrider
so let me understand this... your mower does 12mph, and you want to go "FASTER" while mowing?? And you still expect it to get a great cut??
scott47429
yeah i mean mine will do 11 and cut great but unless I'm mowing a big field i never mow that fast cause in a yard even my 2.5 acre yard its just to fast but it will do it
Ric
I doubt that it will cut great at 11mph. That 11 mph speed is a transport speed, not a cutting speed.
scott47429
well it cuts great i mow a soccer field for the little league with it and i run as hard as it will go and looks great
