Lawnranger
The part that bothers me is that when he did not have 12 volts from the ignition switch going to the small terminal on the solenoid but jumped 12 volts to the small terminal on the solenoid from the battery, the starter cranked the engine. Now he has 12 volts going to the small terminal from the ignition switch and the starter does not engage. What did I miss?
