Lawnranger
- Apr 18, 2012
- 671
So does mine. When it gets to R & R that's when we can have a beer. Post the unit model numbers.
:laughing::laughing::laughing::laughing: LMAO
Now we're getting some where. Last test shows that you have a safety switch problem. Make sure that the parking brake is set, tranny in nuetral, PTO off. Follow the wires to the next connection and check for voltage in and out. This wire will go to one of the safety switches. Take your time and have patience, these electrical problem troubleshooting plans may take minutes or hours. Been there and done that thousands of times with my students. Don't trust you eyes, also check the wires with your finger tips.
Don't forget to check with you're multimeter the continuity in the wire from (s) on the switch to the small wire on the solenoid by taken off both ends of the wire, Ohm's should be low...!
is the switch something like this one..?
