chevyman984
- Jun 23, 2012
- 39
check compression, sounds like it may be low. or timing may be off slightly. check shear pin in flywheel.
I don't have a compression tester, could I just get one at a hardware store?
Autozone might sell them but they are cheaper at harbor freight tools . Is it getting good spark wfter sitting ??? .
Ok I replaced the head gasket, put on a shut off valve, rebuild the carb, and oil the autochoke and I mowed for about an hour, stopped for a 15 minute break, same d*mn thing, I pulled five or six time and it started. When I pull it, I sounded like it was popping in the carb. And it does actually feel like it it turns over real easy when I pull it too.
