chevyman984
- Jun 23, 2012
- 39
I got a lawnmower from my friend, he said it wouldn't run. But honestly all I did was put gas in it. He said it sat behind his house for 5 years. So I fill the tank up and pulled it 2 times and it fired right up. So he said I could have it. I got it home and changed the oil, spark plug, and air filters. And I know I shouldn't be mowing this much grass with a push mower, but I do because I need the exercise haha. So the property is 5 acres andi used it all last year (2011) with it starting on the first pull everytime. I could go outside in the middle of winter and pull it once and it would start. But this year it started acting up
. It starts on the first pull when the motor is cold, but once you get the engine warmed up, and stop for 25 minutes, I will pull and pull 15-20 times for it to start. After it sits there and cools for a few hours, it will start right up. Any ideas what this could be???
