Lawnranger
- Apr 18, 2012
- 671
A fuel pump can go out either way you describe as it depends on what caused the failure. I have had a fuel pump diaphragm stick to the body of the pump and cease to work all at once and then I've seen the impulse line start to soften and gradually cause problems. I'm sure there are other causes of fuel pump failure and a hole in the diaphragm is another possibility. You just have to start checking the basics and branch out from there. Like I said, an engine needs the proper air/fuel ratio, sufficient spark at the right time and good compression to operate and we'll have to find out which one is missing and in what proportion. Look at it as a game of hide and seek.
These machines, and I'm referring to all outdoor power equipment, can be challenging to diagnose as some of the symptoms can be caused by the same failure. For instance, I had a push mower in today and it had no spark so I pulled the small kill wire off the coil and I had spark so I checked where the other end of the wire connects to the cable controlled kill switch and the switch was not opening far enough to break contact so I adjusted the cable and put everything back together. Guess what? No spark. So I checked everything again and found the kill wire insulation was rubbed through shorting to ground. Go figure. If I checked the wire first I would have found the insulation rub through and thought to myself I had it fixed but then I would still have no spark until I adjusted the cable. It's things like this that keep my mind open to more possibilities.
You have to think like a detective and look for all possible causes and sometimes the impossible causes because the mind will not always let a person think outside the box. I may be on the right track in helping you and I may be way, way off course but I don't want to rule out anything until it's verified. Whether it's me or someone else who helps you, eventually your problem will get solved.
