Lawnranger
- Apr 18, 2012
- Threads
- 6
- 671
The only place I have seen derogatory things said about the decades old method, nail or fixed pivot, is in manufactures marketing of their 'better idea'...
No matter how you do a 2 dimensional static balance it will be equally good...
If there were any benefit to a perfectly balanced blade you would find dynamic blade balancing ... As far as I know, no one has came up with that unnecessary service ... YET... :smile:KennyV
Here's a dynamic blade balancer for ya - Magnetic Blade Balancer, 7-05987, 9788, 42-016-0, 95-2002, 42-016
Unnecessary? Hardly! Works way better than the cheap stepped-cone level static balancers and holds the blade perfectly centered on a smooth tapered cone instead of a stepped cone. The cheap level balancers won't work with all blades since some blades have a star pattern and the tips of the stars don't sit in the center of the steps. This balancer also has a moveable arm to check for a bent blade. Laying a blade on a flat surface doesn't always work but with this balancer you can slowly rotate the blade and the arm can be set to just touch the tip of the blade as it passes and then you can compare it to the other end of the blade.
Just for grins, I balanced a blade on a cheap stepped-cone balancer and got it balanced to the point that it couldn't get any better and then I checked it on the dynamic balancer. Guess what? Yep, out of balance enough to set up a vibration so I'm sold on dynamic balancing and nothing anyone says could change my mind.
I fully realize the price is out of reach for most homeowners but I own one of these balancers and sharpen/balance blades for others as well. It pays for itself.
