Simple guy
I thought I had it figured out then I did more research and finally just cancelled my order until I figure out what is what. I am going to get a zero turn and have it down to three choices. Bad Boy mz48, hustler sport 48" and the toro mx4260. I have less then an acre of yard and is flat...just the usual trees, house and garage to mow around.
I currently have a simplicity lawn tractor that has two blades. When I make turns I get grass that is not cut. Sharpened the blades and am going slow...same results. So I think I want to go to a three blade deck to eliminate that issue maybe. Problem is the Bad Boy and Hustler have the EZT hydro's and I have read they are not any good.
The Toro mx4260 has the better hydro in it but it is a smaller deck with two blades. I can not do a 50 inch deck.
I bag the clippings and travel ~10 blocks to the village compost center to recycle the clippings so there is some traveling with the unit.
Not sure what to do. Maybe I am over thinking this whole process but I hate to have buyers remorse.
Any thoughts?
Thanks!
Any thoughts?
Thanks!
