cub cadet quits pulling
dmize53
I have an 1450 international cub cadet. It starts and takes off fine but when on a slight incline the speed drops off and will come to a stop. It has plenty of hydro oil and a new filter. any ideas? Thanks
Did you just change your oil. On my Gold Wing if I put oil in it with the energy saver sticker on the back of the bolt it will start slipping the clutches.
I did change oil and filter in the hydro unit but it seems to do the same. All I have to do is give it more throttle but then when the ground levels off it picksup a lot of speed quickly and if you are not ready for that it could be dangerous.
Check the mechanical coupling between the engine and hydro.
Those hydraulic drives are built very tough and will stand a lot of abuse... Is the cooling fan still intact on the drive shaft? KennyV
