Steelfab66
I'm new to the forum. Hope I can get some help with this problem. I have a 48" Enforcer commercial zero turn that I bought new in 2007. (I think the Enforcer evolved into the Z-force commercial at some point.) My yard is especially bumpy this year and my machine has been cutting out following about 10 bouncy passes about 75 feet long. I've tracked what I think is the problem to the electrical plug moving slightly out of the safety switch that's on the back of the seat. It apparently comes out just enough to cut out the blades and engine. It cuts on and off a couple of times just before totally quitting. Removing the plug and reattaching it allows the mower to restart and it's good for another 10 passes or so and then it cuts out again. Reinstalling the plug gets it going again. The plug has some "ears" on it but no sign of positive attachment to the switch. Could the attachment clip or whatever holds the plug in have broken? My owners manual doesn't go into any detail of how this plug looks and the Cub Cadet tech line guy said he had nothing that shows this plug. And of course to get the plug you have to buy the entire harness for the machine. Anybody out there ever experience this problem? The mower has run flawlessly until this problem developed.
