Gator Mulching Blades for my Craftsman LT1000
Just received my Gator mulching blades in the mail can't wait to see the difference they make with the cut. I had to order these blades from a different website because Sears doesn't offer this style blade for my model lawn tractor which is btw (917.272121). I'll repost to let you all know if the juice is worth the squeeze in buying these blades after I cut my lawn.
Well I'll be using them mostly because my lawn is 3 acres of open grass and I'm hoping it reduces the grass clippings/work on the mower. Ideally I should have a zero turn and I'm keeping an eye open for a great deal. So one question can these blades be a benefit even if I don't have the mulching attachment that closes the deck I'll still be having the deck open blowing grass out
What type of grass are you cutting and who makes the gator blades you purchased?
I purchased them from AMC Parts store through amazon for $35 free shipping. The pic I just attached is my front yard, but all together about 3 acres of flat open ground. The grass is now getting very thick which I like. It started to rain today so I only did a short test on the new blades blades. Seems like it cuts the thick grass even at full speed yet still blows out same amount of grass. Luckily I picked up a pull behind lawn sweeper easy dump for $15 at an auction and this thing is like new I love how it works!
It's a Koehler 18.5 HP and I wouldn't put the plug in I'm not minding the clippings that blow out too much not that I have that lawn sweeper I have a strategic method how I cut the lawn lol so I only have to sweep up a few rows as possible
I use them on two different mowers in the fall. One with a mulch plug, one with open chute. They both have advantages.I mainly mulch leaves not grass and they do a better job chopping the leaves than regular blades.
