Need help in brand if mower
bboy
Hi guys it's Bronson again still sorta a new member. Listen I was wondering if anybody could give me a really good name brand mower they like or prefer see I cut my moms and neighbors grass yesterday with a Toro 21" self propelled push mower. I NEED a about I'm guessing a 36" zero turn what do you guys think not that big of yards I know Dixie Chopper makes a 34" but it's 7 grand out of my range how bout Scag or I think there's a mower called a Bob Cat in a 36" any advice would be greatly appreciated. Thank you Bronson.
Have you check out the new Zee 1 Dixie Chopper mowers? They are about $3500 new.
Both mowers you mentioned are more commercially built. You can get homeowner ZT for a lot less from a number of brands. What are you using it for 3 lawns a week or 60 lawns a week?
Personally if I were you I'd stay away from the Zee1 Dixie. It's running the EZT Hydro gear transmissions and the 19.5HP or 23HP Briggs & Stratton Intek engine which according to Hydro gear the EZT transmissions are only rated for 18hp and below, I think you would be buying a problem looking to happen with that mower.
You can get the Cub Cadet 44" with the commercial grade 20 HP Kohler Courage V-Twin OHV with the 2800 drives for $3799 Lap Bar Control Zero-Turn Riders and it would mow anything you wanted to mow whether you're using it for 3 lawns a week or 60 lawns a week doesn't matter.
do you have any gates to go through? You are where I was 15 years ago... my solution at the time (cutting 5 yards) was a snapper 33 in 13hp zt mower. It worked perfectly. I finally replaced it with a 38 in deck 20hp mower this past month. I still have a need to go through a 40 inch gate. I spent around $2800 for the snapper then, I spent $2300 for the less than 1 year old country clipper this time. Cub Cadet, Toro and several others have mowers in the mid $2k range that will do what you want to do for years... as long as you do proper maint. and keep them out of the weather when not in use.
