I have a mower as stated above, Model 9D902 Type 2005B2 Code 0111155
I need guidance in setting up the carb linkages/springs. When running the motor idles good, at high idle the rpm increases but I can hear a soft backfire. I removed the air cleaner and when I move the throttle lever clockwise I get a better rpm.
This makes me think I connected the linkages incorrectly. This motor is off a lawn mower (yes I changed the flywheel) and does the job good. A good picture reply is appreciated.
Thank,
Dave
Thank,
Dave
