Gene123
I've been trying to get a 5247 (1980) running. It has an F100 engine with "the late model" carburetor. I resolved the problem of gas leaking from the foam filter --- thanks to help from some of the fellows on this forum (Fireman, Two Stroke, & others). Good guys :thumbsup: I installed a new needle & seat as they suggested, primed it twice, and it started like a champ. I mowed for about twenty minutes, turned it off, and it wouldn't restart. Questions: 1. Is the .010" clearance between the coil and the flywheel crucial? I may have gotten it off a little. 2. If I got the float level off 1/16", would that cause the problem? 3. After setting the governor to real low rpms, I screwed in the "adjustable fuel flow needle valve" until it started stalling (or "hunting"), then I backed off on the screw about half a turn until it smoothed out. Could that adjustment be causing it to not restart?
