cub cadet 2186 dies
Blackhawks81
I've seen this topic before, but cant remember the solution. Problem- After 45 mins of mowing , mower shuts down as though its starved for gas. Cool down for 1/2 hour, 45 mins later dies again.
Clean airfilter, plenty of gas, think its a float problem? Has a Kohler motor if that helps!
Thanks!
Thanks!
Blackhawk,
Hope you're still on the forum and found a solution to this problem... I began dealing with this issue on a 1996 HDS-2135 Cub about the same time as your initial post. I've replaced the coil, rebuilt the carb, loosened the fuel tank cap, checked the fuel line - and aside from all the normal maintenance (new spark plug, oil/tran filter change); I'm still having the problem.
I've identified at least 5 other similar posts from various Cub models - all having this similar problem but no final solution.
Something's heating up and if I quickly disengage the mower PTO and choke it a bit; I can keep it running to get it back to the garage.
If I force it and keep running it, it will suddenly just die - then after an hour or two, I'll be able to start it up and run it another 45 min.s to an hour.
Reply back if you're still on the forum.
greynold99
