yardman riding mower
c carter
my yardman riding mower jerks when im in gear an sometimes stops moving could the drive pulley belt cause this if not what could the problem be ?
it could be a few things belt slipping or the trany is going on the frits One of the linkages might need adjustment ...Is it hydrostatic
the tranny is going out, every rider made, over a period of time, they go, out.. inside the tranny are gears and nylon bushings, the gears are made of soft metal, they wear out, the bushings crumble an break, and they are forced up into the pump, causing it to become clogged.. then having to get a new tranny, or mower.. the maintence on the tranny is every 100 hours.. it uses hyrodlic fluid, when that oil gets hot.. it starts destorying internal parts.. so if its never been service. it will not move, or creep along.
I will put my money on the rear belt but replace the front and rear as a pair as they work together.
Sent from my iPhone using LMF
