L Lee2012 Forum Newbie Mar 30, 2012 #1 My husband replaced the battery in our Cub Cadet. Now, the wheels will not move forward or backward. Any idea of what is wrong?
Carscw Lawn Pro Mar 30, 2012 #2 Did he pull out the lever to make it easy to push? Will it move if you push it? I beleave there is a light that comes on to back up does it come on? Sent from my iPhone using LMF
Ric Lawn Pro Mar 30, 2012 #3 Sounds like the Hydrostatic bypass rod on the back of the mower is out, make sure it's pushed in and lock down or it will not move.
SONOFADOCKER Well-Known Member Mar 31, 2012 #4 This model tractor has an issue with the brake getting stuck - try and follow your brake system rods - you will find your brake is stuck on even with the pedal NOT depressed .
Q q4run1 Forum Newbie Apr 7, 2012 #5 Lee2012 said: My husband replaced the battery in our Cub Cadet. Now, the wheels will not move forward or backward. Any idea of what is wrong? Click to expand... Having the same problem, did you find out a solution.
