tough finding machine shop
Community Leader
Location
Pluto
JD M8 1950 model.
Boy its tough finding a machine shop that can just press out and in a set valve guides.
I actually was wanting someone else to do this since my press wasn't wide enough but no go. The time quote I got was 6 weeks and they weren't they could it.
Oh well its up to me to build a platform so I can turn head sideways. Without it the head is too heavy to balance. Just got to wait until rain is out of here. Intake valve seat are a little rough but that is no problem.
The work will get done on my schedule now.
Automotive machine shops use to be everywhere; now they are very hard to find. Younger folks have knowledge of how to do much other than play with their phones.
Have you tried a collision repair shop asking who the best engine rebuild guy are in your area. Second quess, race car teams. I’m lucky, with the amount of industry in this state I have at least 5 machine shops within 100 mile circle of me, one of which is owned by an ex student.
Living out in the countryside has both its advantages and disadvantages. I just don't have the time to spend a week trying find someone to do such a simple job.
Just venting as I have already found a way to use my own equipment to do the job. It just I will not work in the rain with electrical saws.
Most mechanics around here just order short or long blocks and rebuild heads thru the local auto part houses. They don't know how to take a cylinder head apart.
Done got the two intake guides out it just end exhaust ones that is the current hang up as the press center to supports is only 9 inches and I am needing at least 10-1/2 inches. So making a stand out of wood is the way I going to support the unsupported 7+ inches when doing the two exhaust guides.
I always seem to be having to find a way to do things lately that I once could get done otherwise.
I don't have an engine machine shop that are any good within 50 miles and the few that are left are turning into vehicle engine exchange centers more than machine shops.
Along with that it is rare that a machine shop would even consider and oversize bore on a small engine.
Quite literally engine machine shops are fading quickly because most engines small or large are no longer manufactured with rebuild capability, they are designed to minimum specifications and considered throwaway. These shops cannot survive on the occasional "classic engine" machining and rebuilds.
Just about the only parts stock left over for small engines is from machines that were built many years ago and those stocks are fading fast.
Trade schools might have equipment for this , Ain't seen an automotive machine shop in YEARS !
I mentioned racing go cart because I found one that does that sort of thing at a reasonable price. Been awhile but they are still around. Google racing kart and your city - see if anyone comes up. If they do, query them on whom they use for that sort of thing - cylinder boring, guides, etc..
Just shame that I can't get local machine work done.
I think I probably better off just getting myself a mini milling and lathe that should cover most of the custom tools and parts I need to have made. The machinist I had access to has retired but talk with him Monday about the Grizzly I am looking at. When he working all I had to do was give him my OpenOffice drawings with dimensions and he would make the item.
With Grizzly I could start knurling some of the small OHV engine valve guides and the spindle shafts that I get that are loose fitting.
And for the press I need to make special trip to HFT and check their 20T model with tape measure in hand. Currently I have a 12T version. If I change I should be able get most my money back for the 12T selling locally. Or I can just make myself an adjustable metal table. Plenty of bed rails to work with. All I would need to buy is a sheet of flat metal.
Or I could get off my backside and learn to use my Aluminum welder. Just wanted to wait until the off season to drag out and in the setup. I got a set 8 ft aluminum ramps I need to repair. Those 7 ft one are too short for my current needs.
The demand for machine shops has dropped sharply in the 21st century. These shops cannot survive on very occasional requests for help. Instead of boring a cylinder, for example, people scrap the engine and buy another one these days.
The machine shop down the street across America mostly died 30 - 40 years ago. The machine shop I worked in during my late 20's and early 30's, did not do air cooled mower engines. Most shops avoid them. They are hard to work on because they flex so much. The other thing is cost. A new case is sometimes less than a machine shop bill. That said, the guys racing know who does what and for how much.
