Torx screw removal on varator pulley
Les1952
Do I need to be concerned about damaging screw threads when removing cap when there is tension on the spring?
I would really help if we knew what you are working on. At this moment the only thing we have is torx screw and variator pulley. But we don't know what is it on. So lets start with model and serial number of the piece of equipment you are working on.
Most likely it is the General Transmissions RS800. I haven't been yet so I can't advise on it but I would be considering clamping it down just so screw don't go flying.
BTW I just saw something treble. They are now producing 4 ZTR transaxles. The nightmare is getting worst with the lack of info and parts.
At least they are only on electric Z turns. So when the lithium batteries burn their garage down, we won't have to worry about servicing the electric drives.
