B&S 130207-0025-01 / Code 80033107 Carb Linkage Help
oldgearhead
I have a Briggs and Stratton Model 130207, Type 0025-01, Code 80033107. Serial Number: M 626974. It is attached to a hand built go-kart that I received for nothing. Unfortunately the linkage is missing or was lost the last time it was driven. Other than trying to figure out how the carb linkage is hooked up, I cannot find a repair manual, specific diagrams or parts list for these exact numbers. Searching the internet and B&S website, only 130207-0025-99 is available. I cannot discern the differences between these two numbers or their parts. Any assistance in helping with the linkage hook up on the carb and a place I can obtain a manual or parts diagrams, linkage diagram would be very, very helpful.
When I do pull on the accelerator cable the threaded rod moves up. Nothing else is connected and wondering how I put this puzzle together. Thanks
Looks like you have an engine that was on a generator or water pump. The round know goes to the governor and is probably set for 3600 rpms. You’ll need to change the linkage to and adjustable throttle. This engine was born on 1980. I do not recommend you try to covert it.
You’d do better selling the parts off on eBay and using the $$$ towards your project.
I’ve seen many remove this engine and go with a Honda GC160, GC190, GX160, GX180, GX200. These usually have a 3/4” shaft. I see these often on Facebook marketplace and Craigslist for reasonable prices.
The Harbor Freight is a low cost option too
Just my 2 cents.
I believe you can make a working go cart once you get a working engine, throttle control, and most importantly brakes.
Please let us know what you decide?
Just my 2 cents.
Good thoughts on just replacing the engine. It was one of my original thoughts as well. I am assisting my son and grandson (8 yo). Depending on the cost of the parts, I may just use this as chance for my grandson to get some hands on experience. If the measurements hold up on replacing with a predator, then I might just go the "easy" route. I will keep all informed !
There seems to be a lot of support for the Harbor Freight engines on go carts. You may wish to check out Amazon GX160 Honda clones for very reasonable prices. I would not go down the route on trying to covert your Briggs to work with a go cart. The linkage is setup for a generator. The wheel at the top is to fine tune the governor to 3600 rpms.
Looking forward to seeing your go cart up and running?
