I have a craftsman riding mower model and serial numbers shouldn't be reguired, as mostly are the same with these mowers. I want to change my amp meter to a voltmeter , I have the 7 pin ignition switch and need to know which wires ( positive and negative ) can I place these wires on the ignition switch to hook up the voltmeter. I understand the amp meter wires are in series , but the voltmeter has to be in parallel. Cant just hook it up to battery as it will drain it. Is the best solution splicing the hot ( red ) wire up to the ignition switch and the black to any ground. I will attach the schematic and please omit the amp wires ( in can splice them anytinme and draw the lines I need to hook up the voltmeter. Thank you in advance.
