2011 JD Z425--54-inch Zero turn. sale it or part it out?
hollydolly
Last Summer I put new blades, oil, filters, plugs, spindles, pullies, drive belt, deck belt on and within 5 minutes it dropped the 2 valve push rods in 1 cylinder, other than that it always ran great. I always took care of it and kept in my shop when not using it. 15 years is a good run with no problems. Everything on the mower is in good shape and paint is in very good shape. I need to sale it whole or part it out. What are your thoughts and what would parts be worth or how much to to sale the whole thing? Thank you for any help.
Holly.
Hello H.,
Heck, replace the head and put new push rods in it. The valve guides have slowly moved up in the head casting and finally jammed the valves over the years. This was common back when the engines were produced years ago. Machines that were abused and neglected were the quickest to fail.
You stand a better chance of selling it running well than to part it out.
eBay fees, taxes and shipping has gone up so much in recent years that it's become a waste of time trying to sell small engine parts and equipment, especially used.
Facebook marketplace might be an option, but there are always shady people lurking around.
Hello H.,
They are both down in the crank case, one was broken in half. I was able to grab one of the halves. I have a new JD Z325E zero turn 54-inch cut. I will either sale or part it out.
Hello H.,
The Z425 has been a popular model for years. The 54" deck makes it more appealing to cut larger properties faster.
I recommend selling it has is and don't part it out. Good Luck in your venture.
Hello H.,
I had to quit using eBay to sell parts myself as they started hitting me with a 10% fee. Can't even payments for work done without that fee. And my lord the shipping fee are through the roof as I had to use the USPS service here; unless, I wanted to drive 60+ miles around trip.
Now the Z425 is a pain to work on too with the engine sideways and in an extra tight space. Matter of fact many of the repairs you have to be a contortionist if they are done without taking major components out.
On top the Z225 is just nearly as bad as on it you have to pull the engine just to adjust the valves.
Go to You tube look up taryl fixes all on how to fix the valve guides that have move in the head. Have a friend who says he never gets the push rod out of the engine. Says he has one with three in the pan now and they never have caused an issue. I had one that lost the push rods and pulled the pan to get them out. One was laying on top of the cam gear that looked like a paper clip. Have one now that am going to try and fix it similar to what Taryl says.
The rods have dropped to the bottom. I am not going to pull the motor, tear it down. The mower, motor is 15 years old. It has fulfilled its purpose, and I have a new one.
