We all have days like that no problemMust’ve had a brain fart when I posted .020”. hlw49 is correct at .008”-.010”. Sorry about that.
Are you able to do a compression test?
I keep a fairly close eye on those cover bolts and they haven't backed out any since spring maintenance.Hello C.,
First problem I would look for is the upper-case bolts under the edge of the flywheel are backing out. They will rub against the flywheel and also crack the engine block in the front if they are not caught in time. The engine factory failed to put Loctite on them during engine assembly.
Nobody told me to do that, I just saw it in a YouTube and found it helpful. On the other hand, one fellow with the same problem said he'd burned through three starters so now I understand how that might happen. I will heed your advice. This is really sounding like an automatic compression release fault, but I won't tackle that myself and am unlikely to spend the money for a shop to do it.Don't know why anyone would tell you to hold the ignition key to start position and hold it there until the starter turned the engine past the compression stop position. That could burn the starter up. turn the engine backward until it comes to the compression stop position. Then turn it ignition key back to start position and see what it does. Should start the engine.
