Craftsman T1100 Riding Lawn Mower with deck issues.
djpritchard
I’m trying to help my neighbor out who has a craftsman T 1100 riding lawnmower and he has issues with the deck. The first issue is the idler arm assembly has come disconnected as I found it just hanging underneath, and I can’t tell if it mounts to the deck or the frame underneath of the lawnmower.. The other issue is the linkage that I think is supposed to raise and lower the deck seems to have a broken bracket on it. I can’t determine where that bracket was attached to. I’ll attach a pic of both the idler assembly and the deck lifting linkage with the bracket that appears to be broken. I did find a parts diagram of the deck, and I do not see the bracket showing in the breakdown. Img0379 is deck is, I believe the bracket and linkage that is part of the deck level adjustment. I can see a rough edge and rust on the lower portion as it appears in pic. I assume it broke off wherever it was attached. IMG_0380 is pic of idler assembly.
Thank you in advance!
Item #67 783-06769 is the part of the motion drive idler bracket assy and bolts to the frame. This appears to be a redesigned part that replaces it.
Item 64 is 783-06592B Is also part of motion idler assy. Neither are deck parts. And you are missing a step washer, spacer, bolts, and nuts.
