Ariens MaxZoom 2560 transaxle will not bypass / go into neutral
SJMaye
I wanted to perform the purge for air in the hydrogear transmissions. I pulled both levers back as in the manual. They both pulled back, but I did not feel the bars lock on the the frame. The bars appear to pull back as far as the images in the manual. I expected the bars to have a notch to positively engage. They never did. I raised the rear wheels off the floor with jack stands and started the mower. After starting the mower and releasing the parking brake I slowly moved the steering levers back and forth. The videos I saw said the wheels should not turn when in bypass. Mine definitely did. And not just a little bit. With the wheels back on the ground and still in neutral I tried pushing the mower. I could not. It felt as if it were at least still partially engaged.
Does this make any sense at all?
I know on my Gravely that it may seem that the lever is fully back but it's not. Ya really gotta pull on those suckers sometimes to get them to disengage. One time I wrapped a strap around them to get a better grip
Hey Bullet Bob,
I really appreciate the reply. I wondered about that. I had, in the past, tried to do just that some time ago without success. Now I am trying again. After watching several videos they bypass lever appear to move very freel. This led me to think if I really pulled hard on it I could damage it.
I can say that when I pull the levers back to the neutral / bypass position with the wheels off the floor, both the left and right side wheels rotate. If I try to drive the mower while the bypass levers pulled out the mower will drive. I will look closer. I am obviously missing something.
It appears I was doing this right. The lever has a notch where it should be when in bypass mode. When my bypass lever is in this notch it is not fully bypassed. The wheels rotate while in the air in bypass. I tested it wheels on the ground in bypass and it would move the mower. I did this just to test and did not push it.
I guess I could expect this on one of the two hydro units, but not both. I have to be missing something. I tried calling Hybro-Gear tech support. It was a dead end. They pawned me off on a local shop that no longer even services Hydro-Gear.
I will keep poking around the internet...
I've experienced a little creep when the transmissions are in bypass. There are adjustments to be made to each transmission. Refer to the owners manual for adjustment.
Sorry. I don't understand what you mean by, "A little creep". Mine almost feel no different between in bypass mode vs not.
I've done Toro mowers that when in bypass the wheels would move very slowly (creep). I could still push the mower around. There are adjustments on each transmission that will take that out. Try putting your mower on flat ground and putting it in bypass. Can you freely push the mower?
Look for some YouTube videos.
