TB90BC Bushcutter-Help
Boyde
I give up, I need help. I have been working on my Troy-built TB90BC Bushcutter. It is old, but still use to work. It will run on choke. Idles great and runs great for about 30 seconds, then just dies. I have cleaned the Zama C1Q-P18A carburator in my ultra sonic cleaner over night. (Before this it would not start). New sparkplug, new diaphragm, new gasket, try with gas cap off. It will run on choke forever. It reves up real clean, idles at a good rpm. Then just dies. I am going to try to attach a video and two still pics.
Please help.vedio of TB90BC
Have you checked the fuel pickup and fuel lines? It sure seems like it's not getting enough fuel.
Thanks, I did put a new fuel filter on it, no change. I have not replaced the fuel line, yet. I have been thinking the same (I just went for a long walk, when I do my best thinking). The lines do not appear to be cracked or split. However, the primer pump does seem to be drawing air, not consistent solid gas.
I would replace the fuel lines. The primer can draw from the carb to the tank. That can end up pumping more air than you'd expect. If it starts well, I'd assume the prime system is working. Where was the filter you replaced? Was it in the tank? Check on what Rivets said too.
