MInimum would be a 6x10. The length is a consequence of the width. will need a 6 foot or wider trailer for the deck which a 61 inch deck will be closer to 72 inch with the discharge.
My every day trailer that I use at the shop is a 7x14 dual axle with brakes on both axles. If you have never pulled a trailer with a vehicle with 4 wheel antilock brakes on loose material a trailer without braking becomes an adventure in stopping.
