Uneven Grass Height with JD srx75
Chazzy-Chas
New member here, don't know if this is the right place to ask this, using a John Deere SRX75, when I mow my yard my grass is higher in the middle of the path, lower on the outer edges, blade is always shape, I've tried moving slower, tried moving faster, tried lower and higher deck heights, always the same results low outer edge, high in the middle. What the issue, can't figure it out, any and all thoughts welcome.
Did you level the deck by using the blade tips or deck shell? Did use an OEM belt? John Deere tractors are very fussy. Is the center blade turning as fast as the outside blades? Will need an assistant to help with this. Are you mowing at full engine speed? All these can contribute to the problem.
The first thing I would check is the wide open throttle engine RPMs. Mowing at anything below maximum recommended engine RPMs is pointless.
Never really thought about that one, believe I'm at full throttle when but could have gotten bumped going around between and through bushes, very good thought thanks for puttin the in my head, I'm going in for a tune-up myself so then I'm able I will most definitely keep eye and ears (no head phones and loud music) on that one. GOOD ONE MParr
I will updated when healthy enough to rotate the leafs
Thanks to all and everyone's input
