Model 130292 will not run unless fully choked
If you're choking it to make it run, it's starving for fuel , you still have a fuel problem with the carb or fuel pump diaphram
Hi Bertrrr, I do realize that and have been very careful to do it right with the install. Even replaced the diaphram, just doesn't make sense!
Hi Bertrrr, I do realize that and have been very careful to do it right with the install. Even replaced the diaphragm, just doesn't make sense!
No. Order a new aftermarket carburetor off eBay.
I’ve had good experience with them.
I believe you know how to correctly connect the linkage and it’ll run great
Understand now Mate! I wish you good luck in your hopeful success. My experience has not gone so well. Apparently the check balls get stuck and the carburetor will not work correctly
I’d just order an aftermarket replacement, connect everything back up correctly, and call it a day.
Best wishes on the sale. Just sold one of my homes last month and definitely understand the limits of time.
Found it!!! See the stick in the image, brand new diaphragm does not seal :( Thanks for your trouble :) MIke
