Cant ID drive belts old yardman
Scooby2
Ive got an old yardman which im guessin is from the 1980s. It has no plate on it anywhere. Its got 11hp b&s motor and two individual square headlights.
The variable pulley broke so I had to remove everything and weld it. The drive belts have chunks out of them so I want to replace them. The only problem is I can’t find any suitable belts anywhere so if anyone can help me with ID numbers for the belts or where I could get them, I would really appreciate it I’m in Europe.
The length of the belt from the motor to the variable pulley is 53 cm and length of the belt from the transmission to the variable pulley is 31 cm. They look like they’re about a half inch wide.
See photos below fot potential to identifying the lawn tractor
many thanks in advance
Michael
got to be the wrong measurements.
53 cm = 20.8 in
31 cm = 12.2 in
Never seen belts that short on a front engine rear transaxle rider.
53 cm = 20.8 in
31 cm = 12.2 in
They are short. Here is a photo of the underneath
Sometimes a model of mower can be found by using the engine model information, but I can't read the numbers on the tag on the engine in the picture.
Here is a pic of the engine tag. Any further info would be greatly appreciated
a search with Google Lens brings up a similar tractor made by MTD and sold by many names. Without a picture of the "variable pulley" it is hard to match it, but this is one pulley shown in a 1994 model. It is sold by different names too in Europe. https://www.ebay.com/itm/285518013224
One can also search using terms like variable pulley MTD 1993 1994. This is what comes up. https://www.amazon.com/s?k=mtd+vari...annelId=500&clpRedir=Y&plpRedirect=mhFallback
Might want to use Google lens to search for parts diagrams for that mower. Right click a photo in Chrome and select Search with Google lens.
Engine is from 93 which one would assume something around 93 or 94 but doesn't appear to be the original engine, since the hood and grill are from the mid 80's.
