The thing that is fooling people is the 120 psi. That may not be enough for this engine depending on compression ratio. Also that 120 is most likely a wet compression reading. Like the different between running a compression test and then adding oil to the cylinder to get a second reading. And wet test will be higher in most cases because the oil seals the rings. If you want to compare compression do a cold reading. Run the saw and then recheck when hot.
That score mark is not only bleeding off compression it is being fed directly into the crankcase which also effects the vacuum up cycle of the piston to draw in the next load of fuel/air.
