Bmwz3coupe
- May 28, 2022
- 40
What should be the running RPM's on the above Briggs motor please. It's on a Toro 21564 mower 2025 model. Thank you for your answer.
Running RPM's please not max.Maximum RPMs 3,000
If you are cutting the grass, you need to cut at wide open throttle ( maximum RPMs).Running RPM's please not max.
