- May 6, 2010
- 11,995
This one has me puzzled. Engine starts cranking as soon as the key is switched to the on position. New JD key switch/circuit board. Older below 70,000 serial number unit. Start wire is getting power at the circuit board X1 pin 5 with no crossover power between any of the other wires connected to the circuit board. So something is triggering the start relay on the circuit board. Old key switch/circuit board has same symptom.
