Badnewsbarrister
I recently installed new motor (thanks to those who helped me identify the correct replacement mower) and now have a new problem. After running the tractor for about 30 minutes, including a couple trips up a hill, the tractor won't go forward or reverse. Letting the tractor sit for a while restores the power. When I changed the motor, did my belt become loose so that it slips when warmed up? If so, is there a way to tighten the belt? If the problem is transmission, is there a way to fix without replacing the entire transmission? Thank you
