Did you buy this and the seller said it was rebuilt or did you rebuild it?Engine was rebuilt. Bored, new pistons. valves ground and seated. Does not burn any oil. Coils on both cylinders firing. Compression is 100 psi on both cylinders with carburetor full open. Should be around 165 psi I am told. Any thoughts appreciated.
