Linkage for Husqvarna YTH24V48, with Briggs and Stratton Engine model 44R877
vmceng
Hi All!
Need linkage photo or video for Husqvarna YTH24V48, with Briggs and Stratton Engine model 44R877; type 0001G1.
Have seen quite a few videos but none addresses the linkage for the above setup. Can you please help?
What are you with? The Choke or Throttle linkage. Or it the governor springs? The setup is pretty well self explanatory.
Its a Nikki V twin carburator 791093. There is a link and sprring that goes from the Govenor to the carburator. The hole with platic groumet ties to the bottom linkage for the speed. Hacve spent hoursseaching the internet and no one has a diagram for that carburaor. TxsIMG_3327.jpg
please see my recent post.
See Post #5 where I gave you throttle linkage PN that goes from the carburetor to the governor arm. I also include two governor spring in case you lost them. IPL does not show a spring from the governor arm to carburetor.
You have to have the carb off the intake manifold in order to install the carb end of the throttle link; can't install it with the carb and manifold bolted together. Then once installed then hook the governor end of the throttle link in the governor arm before mounting the intake manifold.
Now if this engine has an auto vane its spring connects from the air vane to vertical post on the manifold. This is so the air vane closes the choke when the engine is not running; so you got to have the link installed for the choke.
