Hello; I'm about to replace the 717-0800 Variable Speed Pulley on my '89 MTD Rideing Mower.
The original 717-0800 has been on since new. I'm getting a little bit of noise inside the Tractor Frame. My Mower has 2 Idler Pulleys and I'm replaceing both as well as New Belt's. I'm not sure which Idler Pulley is makeing noise,, so I'm just going to replace both of them.
The 717-0800 Variable Speed Pulley has 2 Tiny Pin Hole's ~ On Each End. Are These just Air Breather hole's or do I need to Inject some Grease or Lubricant in them. I would need to use a Needle Grease Fitting to put some grease in and I have one, but I don't want to put any lubricant in them if they are just air hole's or vent's to let condensation water out.
I plan on adding some grease to the Needle Bearings and Lube the Shaft that the Pulley Slides Over.
Any other Advice about this install is Much Appreciated.
