rebuilding a 125K02-0189-E1 06041958 engine on a Toro 20055 mower. Trying to keep costs down on the rebuild or it doesn't make sense. Likewise, it doesn't make sense to put parts back in that only have a short life expectancy left.
Is there any reason not to reuse the cam and governor? The nylon is 2006 vintage, and the engine has somewhere between 300 and 500 hours on it. The cam and governor have been inspected and they appear in good condition, however they are made of nylon, which is not like a metal part. The teeth and lobes appear fine. The governor and compression release lever are smooth in their actions. Both lobes are smooth with no pitting or galling. The exhaust lobe is .0035" shorter than the intake. Not enough to be significant. The cam lobes are tight on the shaft and do not move.
A new Cam is about $66 and Governor $35, so replacing them is a significant cost. I don't see any return mechanism on the compression release other than gravity. The book refers to a spring in the movement, however there is none on this cam, or in any of the photos I have seen of other cams like it. The movement on the governor and its spring are smooth and consistent. Threads posted in various places online seem to think that the nylon cams made today are inferior in quality to new ones. I don't know if that applies to factory parts, or all parts made today. I certainly don't want to replace these to only put in a part that has a higher failure rate than a 20 year old part.
