Ever since I got this mower brand new, it doesnt matter if the engine is hot or cold, I have to shove the throttle adjuster into the choke position to get the engine to start. Is there anything I can do to stop needing to do this? I recently got rid of a 26hp kohler that would start even if the gas was fully water
and none of my other small engines exhibit this behavior unless they need carb cleans or replacements... with a new engine this shouldn't be necessary already.
Additionally when I go to start the engine, the starter will engage and nothing will happen for a second or two before it finally starts cranking, like its a weak battery but its not. What would be causing this?
Finally, I had a coil go bad tbe first summer I had this mower. I replaced the coil, and after that the hour meter just flashes all 8s when I have the blades running. How can I fix that?
My mower has a height adjust knob like most others... but... when I set it to 3.0 my blade tips are only 2 inches from the ground! Wanted to ensure my deck was level because my stripes suck! So I pulled the blades, pressure washed all the green off of them, sharpened and balanced them, and proceeded to check deck height and found out the knob was fully 1 inch higher than the actual cut.
So, I raised the deck the entire inch, so the knob matched the blade distance from tip to cement, and now I cannot use the other knob that locks the deck in a fully raised position! Anyone else encounter this and have a fix or do I have to do some silly math in my head to make sense of what cub cadet did??? Thanks
