Help identifying engine
Gumby83
I’m trying to figure out what engine and possibly model/serial numbers.
See pictures - I’m guessing what’s left of the white tag had the info I needed.
The only other tag I see is the emissions label.
It’s installed on a Husqvarna Z248F - Model 967336703 - Serial 021716C002148
Thank you.
I’m sure it is an FR model, 726cc. Don’t know if it is an FR651, 691 or 730. I would need the number stamped in the top of the carburetor. It will be a five digit starting with a 4, (4xxxx). Please provide this number and if it also has the flip up air filter cover. (FR)
google ai
Engine family KAXS.7262CB refers to a Kawasaki 726cc V-twin 4-stroke gasoline engine. [1, 2, 3]
Because Kawasaki uses this engine family designation to group multiple specific engine models for emissions and compliance purposes, this family encompasses a few different variations. The exact engine model and its horsepower depend on the specific Kawasaki series in your machine: [1, 2, 3, 4, 5]
  • FR Series: ~21.5 to 24 HP
  • FS Series: ~22 to 24 HP
  • FX Series: ~23.5 HP
  • FT Series (EFI): ~26 HP [1, 2, 3, 4, 5, 6]
Commonly found on zero-turn mowers and lawn tractors (such as Toro, Ferris, and Scag), these motors feature overhead V-valves, cast-iron cylinder liners, and a 78 mm bore with a 76 mm stroke. [1, 2, 3, 4, 5]
If you can locate the exact Model Name or Spec Code printed on your engine's silver and black ID label, I can give you the exact horsepower, part numbers, and specifications for your specific unit.
