Yes a old on but one of (4) in the family . This unit had a transmission replaced about 5 years ago and was used as a spare for the family (brother-brother-in law- me). I had local Honda dealer adjust speed cable this year at start of season and it was slow. Ran like a champ until about 3 weeks ago. Was about 15 minutes into my mowing and on flat ground when it just stopped moving . First thing I thought was a cable came off . It made no indication or sound iyt just stop .I have tried everything and basically taking it down to where I could remove transmission if needed . Still no movement .No oil around transmission . Belt is ok . Cables seam ok . Yesterday I adjusted the cable to the handle that engages the drive wheels and did get a small movement forward but only once. If I run the mower and have the drive and engaged and pull back you get the resistance from the transmission and some sound but you cannot pull backwards .The local Honda guy doesnt even want to look at it as says it 24 years old has to be transmission . Im lost what to try to prove it is the transmission ? Im just confused why it sopped on a dime and no indications or soujnd?? Help
