considering a light lawn mower lift
Spacecrow
Hello all. Watching a lot of lawn mower videos and notice guys using a hydralic table thingie to raise a light push mower off the floor. The idea is to raise the mower up to a height where work on them is practical. Who sells these things? Thanks for reply.
  • Like
Reactions: dhd
A motorcycle lift table is perfect if you have the room for one. I bought one years ago for my Harley Trike, and it gets used mostly for small engine and ATV work.
Amazon and eBay have them. It is a matter of if you want an electric, hydraulic or air operated lift cylinder.
They also turn up used on Facebook marketplace once in a while, so someone local to you may have one that they no longer need.
I recently purchased a 1000 lb. capacity Harbor Freight Lift Table and added a larger 48"X 60" wood table top to the original metal table top so my riding mower could fit on the table top. Here are a couple of photos, one with the table at its lowest height (12") and after backing my mower up the ramps on to the wood table top and the next photo after pumping the table top to it's highest height (34"). I was surprised how easily the manually operated hydraulic foot pump was to operate.My riding mower weighs 570 pounds.
I wish I had not waited sooooo long getting a lift table. It's one of the best purchases I've ever made.
Lift Table before modifications.
dhd thank you for the reply. I am so happy for you.
Did you work out a solution to raise your push mower to a practical working height ?
