Thanks....the B&S site shows what I call a "parts group" part number, inclusive of valves, springs, stem seal...not just a part number for the head itself.....for two head groups. I'm not sure how to determine which group number is for my engine.Well which head as Partstree has both in stock?
BTW I have yet to see an OHV small head with guides not installed. Matter you can't even buy the guides separately.
Thanks, I didn't see any orientation choices in the B&S site. As I broke down the engine I used punch marks on the heads and on the rods and block to locate them during the rebuild. Internally there are numbers in the casting too. Plus closest to the PTO end of the crank.Well while sitting looking the carburetor end the engine # 1 is on the left and #2 is on the right.
The head with the intake port on the right is the # 1 and the one with intake port on the left is the # 2. This is looking with the rocker cover side facing you.
If that doesn't work for you post a picture of the head you are needing.
Working on a 407577-0292-E1: B&S site says cylinder head no longer available. I need to locate a head with the guides installed...appreciate help in advance.
bartles
www.partstree.com
The area around the exhaust guide has small , 3,;"hairline" cracks. Someone has been inside this engine before me.Which cylinder head? #1 or #2 there is a difference.
Why do you need a head?
