JustinRaney
Where should the fuel mixture screw be adjusted to not the one on the throttle plate? For 425001x8 murray mower.
Murray does not build the enginesWhere should the fuel mixture screw be adjusted to not the one on the throttle plate? For 425001x8 murray mower.
The engine build information is stamped in the valve rocker cover or the fan shroud.Where should the fuel mixture screw be adjusted to not the one on the throttle plate? For 425001x8 murray mower.
Will you stop being so damn stubborn and provide us with the engine's model, type/spec, and date code off the rocker cover or decal. Note sometimes they get turned upside down. Otherwise we can't help you.believe its the lp115 carb? for the 17.5hp briggs and straton engine.
