Removed original and installed kit as prescribed on the forum..Started up adjusted air screw a little all is well smooth thru all ranges and no hunting at all. Big problem when you shut off seconds later fuel runs out the carb throat. Now i use my fuel shutoff valve to run carb dry then turn off key.Whats the deal i would think it must be float related, or needle valve ????? I would think it would be running very rich but the new plug shows ok. Oh yes 1 more no choke when starting cold.
