This is exactly what happened.
I started the mower and pulled the button to engage the blades to mow the front.
I did one pass that was about 40 ft long and then I took a left down the driveway and did the same thing on the side to mow that grass.
I drove up to the front lawn and engaged the blades, however they did not work.
I tried it a few times by pulling the button up multiple times and nothing.
I then drove back up around to the back of the house to see what the problem might be.
I turned the mower off and then got off to take a look underneath and saw nothing.
I tried to start the mower and then it would not start again.
I tried jumping it and nothing.
I can hear the electrical engaging and can clearly see all the electrical working, however nothing starts.
Does anyone know what the problem could be?
Could it be a bad mower engagement switch?
