I've been around small engines all my life, back in the 70's when everything still had ignition points, we rarely had to mess with them. It seemed like they were a set 'em and forget 'em thing.
Now, if I put new a new set of points, & a condenser in a mower, a week or two later they need to be cleaned again.
I picked up an older Rickles Home Centers push mower, the thing looks like brand new but it had no spark. I pulled the flywheel, and took a close look at the points and they looked fine but with a bit of corrosion on the surface. I dragged a bit of emery paper throught them and it regained spark. With some fresh gas it ran fine. That was Sat.
Now, several days later, it again has no spark.
I tear it apart again, replace the points with a fresh set from B&S gapped at .020", resealed the little points cover, and put it all back together and it fired right up. This morning, its got no spark again, the points again failed to make contact.
I gave up and stuck a Nova module on it.
But, what changed? The points are older inventory, so not from China. the condenser tests fine even on the original set. They weren't burnt or pitted, just dirty or lightly corroded. They only sat over night, it was running when it shut down, then 12 hours later no spark.
I've had this happen over and over again lately.
There is no oil leaking into the points cover and all it takes is to wipe a bit of rough cloth through the points to restore function. I've been dealing with this on both push mowers and tractors. I've even intentionally left the flywheel off, and tested the point for continuity and they were fine when it got turned off, but after few day sit, they loose continuity. These are all machines that are stored indoors in a shed or garage. The very same building I've been keeping my mowers in for 40 years.
