Bmwz3coupe
- May 28, 2022
- 40
I looking up a carb for a mower and it gives two different carbs part numbers. The note says "use before code date or after code date" where do I find this code date please.
No numbers on block. There is a MAR 16 12 below the engine number though.The number will be electronically etched on the flat side of the engine block opposite the carburetor. For larger single cylinder and V-twin engines, the number are stamped into the top of a valve cover.
That converts to date code 120316XX.No numbers on block. There is a MAR 16 12 below the engine number though.
I believe you have solved the code and I learned something new. Thank you sir.That converts to date code 120316XX.
Can you take a picture of what you are seeing. We are making blind guesses try to help you.No numbers on block. There is a MAR 16 12 below the engine number though.
