Hello S.,
That "debris" was fuel that has sit too long in the fuel tank and carburetor/injectors or in a storage container. Modern fuel does not hold up like it did years ago, especially ethanol blends. The fuel breaks down and creates a "shellac" from the additives in the fuel has it evaporates. This stuff begins to flake off and plug up the fine passages inside carburetors weeks after a machine is purchased and used a few times.
Of course, the factory warranty clearly states this is not a covered "defect", but most sensible shops take steps to prevent this problem, or they correct it later for free to maintain their reputation and customer relations.
Note: Don't expect the shop to only put non-ethanol fuel in their equipment during initial setup and test running.... Some areas do not have it available.
I am not a big fan of pour in fuel additives, but I have been using Ethanol Shield for a few years and have had good results in my own equipment. Products like Sta-Bil do not hold up well in my area of South Texas.
Ideally, the best thing to do is run your equipment and use up the fuel all through the year and not let it sit for months at a time.
