Chock throttle
bryantsplace1
I have a Scag Tiger Cub with a FH601V-CS29 engine and I have lost the clip on the chock throttle to hook to the linkage rod. Is there a part number for the plastic clip or do I need to purchase the hold throttle rod?
Also can someone confirm the part number for that particular part. Thanks in advance.
Chock? I think you mean choke.
Those plastic clips usually come as part of the carburetor assembly.
Not necessary as the metal bushings do wear out and fall off. Use Kohler 25 158 11-S Bushing.
Kawasaki has this part as well. It may work on the old FH engines.
If you have a PN I'll add it to my database otherwise all I have the Kohler and Stens PNs.
EDIT
Nevermind the Kawasaki PN is 13280-7004 which has a hook for a spring. The Kohler one doesn't.
I have purchased these clips in the past at auto parts stores they use them on rods for doors and tailgates. If I remember correctly it was an assortment pack and I was able to find a match.
Hello H,
The assortment packs for automotive door handle, tail gate and power lock rods look similar but they are slightly larger than the ones used on small engine applications.
You can buy these online. I keep these clips in stock.
